fuse box for the stereo????
busterock
12-31-2003, 11:55 PM
...im having a problem with my stereo..it seems like i may have blown a fuse or somethin...does anyone know where its fusebox is???its a 94 cutlass supreme.....
weedahoe
01-02-2004, 05:37 PM
if you think a fuse is blowing, get a VOM meter and chk for voltage on your fuses and if one is blown then you need to chk for continuity to ground to locate a direct short, you could also be pulling to much power in which the fuse will blow. get a meter and start checking things.
walty83
01-02-2004, 06:18 PM
odds are it is under your dashboard on the drivers side. like back behind yur parking brake pedal, or if you dont have one, on the left side back by the epdals. thats where it is on most cars and on my 83. i assume yurs in there too,check it
tbub
01-06-2004, 09:44 AM
i have a 93 and the location of that fuse is under the glove compartment. Open the glove box and remove plastic liner. There you will see the fuse box.
Todd
