Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 12-31-2003, 03:31 PM   #1
bmw325i
bmw325i Normal reputation
trans. overfull?
switched out a 700R4 automatic and fluid is over flowing out of what appears to be the passing gear cable conn. when engine is off. I filled the thans. to just under top of 1 pint low line then drove to warm and rechecked, it was ok. Shut engine down and near running drip appeared until the add 1 pint mark and stopped. Is this to full to be draining that high above the fluid pan? Could the dip sticks be a different length on near same year of an 87 camaro with the 2.8L V6? I pulled this at u-pull-it salvage and don't remember if I changed dip sticks and/or filler tube.
TIA
bmw325i is offline   Reply With Quote
Old 01-01-2004, 12:48 AM   #2
hot(gay)Rod
Banned
hot(gay)Rod Normal reputation
correct me if i'm right, but arent you supposed to check tranny fluid while the engine is running? anyway check the vent tube in the tranny and make sure it's not plugged
hot(gay)Rod is offline   Reply With Quote
Old 01-01-2004, 02:03 PM   #3
89IROC&RS
89IROC&RS's Avatar
89IROC&RS Normal reputation
Re: trans. overfull?
yeah, you are supposed to check trans fluid with the engine running, thast probly your problem, although an incorrect dipstick is a possiblity. not sure on that one.
and hot gay rod, im impressed, that was a nice post, was that so hard????
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
89IROC&RS is offline   Reply With Quote
Old 01-01-2004, 02:13 PM   #4
bmw325i
yes, filled while running, just little less than fullon the dip stick. then drive to warm fluid because it will expand a little after warm (air induced in fluid will show like expansion of fluid). I will be adding more fluid today and spray with powder deoderant to show exactly where leak is.. I have to use small mirror because leak is above trans. fluid pan mount flange. I just don't think the fluid level is supposed to be above pan flange that far.
Old 01-01-2004, 02:32 PM   #5
89IROC&RS
89IROC&RS's Avatar
well, i do konw there is a vent tube on the top, im not a trans guy, but there could be a check ball or soemthing that isnt working or somehitng, but seeing as i ahve no idea, ill just sit and be quiet good luck man
Bookmarks
Google
Web AF
