Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro > F-Bodies (Camaro and Firebird) > Camaro Discussions
Old 12-31-2003, 11:04 AM   #1
Marr-TA
Marr-TA Normal reputation
Question woo woo noise from rear end/wheels/u-joints?
My 94 TA 6-speed has a very odd noise coming from the rear of the car. I cant tell if its the u-joints, wheel bearings or the diff. It gets louder as you accellerate and I can take it out of gear and the noise is still present. It sound does change when I turn the wheel.
Marr-TA is offline   Reply With Quote
Old 03-29-2004, 10:10 PM   #2
brad97bird
brad97bird Normal reputation
Re: woo woo noise from rear end/wheels/u-joints?
I have a 97 firebird. When i bought it i was aware that it had a bad right rear wheel bearing. However when i got the prob checked out i not only had a worn out wheel bearing, but also bent right rear axel which caused the bearing to go out. im almost positive that you have a worn out wheel bearing, mine was making the same noise especially when going around curves.
brad97bird is offline   Reply With Quote
Old 03-29-2004, 11:08 PM   #3
Chevyracincamaro
Chevyracincamaro's Avatar
Chevyracincamaro Normal reputation
what kindof noise is it? is it a high-pitched squeel, or a thunking noise, or a grinding kindof noise?
Chevyracincamaro is offline   Reply With Quote
Old 04-09-2004, 06:16 PM   #4
Marr-TA
Its not a grinding or thunking and it is more of a low pitch whiring kind of noise like a siren almost. The noise seems to be consistent with the wheel speed. I am fixing to change the diff oil and will be pulling the axles and replacing the bearings. I was just hoping someone has had the same experience so that I stop worrying about the diff being bad. Thanks.
Bookmarks
Google
Web AF
