1995 grand am door panel removal
johnjay28
12-30-2003, 09:57 AM
i am trying to replace the small glass on the rear door of my 1995 grand am SE. no pwr windows. could someone guide me on replacing this window. i have removed 3 screws from the panel and the window crank. the panel still seems to be held by something. thanks in advance.john
xcougar0747
12-30-2003, 09:34 PM
There should be a screw behind the plastic reflector, also if this has a plastic bezel around the door handle there is another screw behing that ( im not sure if that was the 95 or not, other then that use a putty knife or something alittle wider then a screw driver and carefully pry the panel outwards starting from the bottom to release the plastic clips that hold the panel to the door ( it takes some pressure to release them but that should be the only other thing holding the panel on.
johnjay28
12-31-2003, 11:36 PM
xcougar i forgot to mention Happy New Year to ya. john
ferrari_adidas5
01-01-2004, 10:13 PM
there are also just these things that snap in, i think there are 2 or 3, and you have to carefully pull them out. if you can pull out the door panel at all, look in for a area that one goes in.
xcougar0747
01-01-2004, 10:20 PM
Same To You John
