Stalling question yet again.....
marathoner
12-29-2003, 03:00 PM
Hello all....I'm brand new to this so bare with me.
I have a 95 JGCV6 and my main problem is that my car wants to stall but it doesn't. I just replaced the fuel filter, spark plugs and wires, dist cap and rotor and recently got some carb cleaner and clean where the throttle body. I would be driving great at 60mph and then when I get to a light and put my foot on the brake the rpm would go down to zero and then it would jump back up but the engine doesn't die. I think it's an electrical problem and can you reset a car computer by just disconnecting the battery. Can it also be the TPS sensor? Can anyone help? Thanks a bunch!
tdenkler
12-30-2003, 01:01 AM
sounds like bad IAC motor(idle air) sits on throttle body.
01Silver
01-09-2004, 12:19 PM
try cleaning the IAC valve...It is the black plastic attachment on the throttle body closest to the valve cover. There is a wire harness plugged into it. It requires a torx 20 (pretty sure) screw driver to remove it. Just be careful not to tear the rubber O-ring when taking it out. Just use a little TB cleaner and wipe it of with a rag. If this doesnt work, you might need a new one.
