picture needed
Tercel GTS
12-28-2003, 11:18 PM
I need a picture(s) of a 90-93 Celica engine bay WITHOUT engine and transmission. Please post one here if you happen to have one or access, thanks
illGT4
12-29-2003, 01:13 AM
look on http://www.turbocelica.com
I believe Chris has one on that site. If not, if you email him, he'll most likely have something for you.
I'll look while you do that...
later,
chris
illGT4
12-29-2003, 01:25 AM
Here you go:
http://www.turbocelica.com/Autos/WhiteAllTracWeb/Body/EngineCompartmentFacelift.htm
More if you look around Alltrac.net
Tercel GTS
12-29-2003, 06:59 PM
Thank you!
ghetto7o2azn
12-29-2003, 08:57 PM
awd 396whp and 12.5 time?? shouldnt he be in the 11's at least.. how much does an alltrac weigh?
illGT4
12-30-2003, 03:16 AM
he wasn't running at full potential. Not even close. he was running half the boost he could have run.
Alltracs wieght about 3300#
With Flat shift enabled he should be able to lower his times close to 11s.
Chris
ghetto7o2azn
12-30-2003, 11:26 PM
oh ok... cause there's a guy in the mr2 forum and has i think 320 at the wheels who is in the high 11s and i would think that that alltrac with over 40 more hp and awd would be faster unless it was a lot heavier or something
Tercel GTS
01-02-2004, 12:59 PM
Thanks for the pic links, anybody have a link to pics of the underside of same model car?
illGT4
01-04-2004, 06:49 PM
What are you looking for?
Or what would you like to know?
I just saw some nice scans of some floorpans, but I can't recall where they were at...
CHris
Tercel GTS
01-06-2004, 01:46 AM
Thinking about getting a front structure from a celica, wanting to compare the pic with my own car. Basically exploring options till spring time so I'll have my plan in order. I'm looking at building a cradle similar to what a camry uses, but it's 6" wider than my wheelbase ;) I'd like to get the wheelbase hub to hub of a 93 GT, and how far center to center for the front control arm mounts. I'm looking for a street car, not a dragster, and with 7" rims the factory wheelbase won't give me much right hand turn before the tire hits the transmission. The celica seems much narrower than the camry, and was powered by the same block size engine, with a similar transmission.
I wanna have fun, not a deathtrap ;)
illGT4
01-07-2004, 02:38 AM
Sounds different. Good luck! :)
