Installed short shifter...problems!
T!mmy
12-28-2003, 06:27 PM
Ok I installed a short shifter and now it seems like going into gears is harder. It's like you have to push that much harder to get it into a gear.
ANy help?
thanks in advance
Brian
pisetup
12-28-2003, 07:53 PM
Are you using aftermarket bushings?
T!mmy
12-28-2003, 08:31 PM
no...
99civic03
12-28-2003, 09:14 PM
You NEED bushings! It will make shifting 1000x smoother, get some!
T!mmy
12-28-2003, 09:35 PM
Where is a place that has good ones?
thanks
pisetup
12-28-2003, 09:37 PM
eBay - Neuspeed bushings
T!mmy
12-28-2003, 09:44 PM
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=42612&item=2450339760
T!mmy
12-28-2003, 09:48 PM
liek that?
T!mmy
12-28-2003, 10:31 PM
ok I went to the car to try and describe how it is better...whenever I push the shift lever forward it seems like something is too tight. It's just harder than it should be...it goes into gear fine it just feels tight. What do ya'll think?
BullShifter
12-28-2003, 10:44 PM
Did you follow the install directions?
You have have over tightened, not greased, forgot a piece. Go back & check your work.
Summit Racing has the stabilizer bushings for $10(energy suspension) they should be used with a short shifter, but won't solve your issue.
Which shifter is it?
T!mmy
12-28-2003, 10:53 PM
I didn't have instructions...I bought it from Kicker1_solo...do you have a set of standard instructinos on how much to tighten them?
BullShifter
12-28-2003, 10:57 PM
http://www.binghamtonlife.com/manual/2gsm/images/91-13-27.jpg
http://importnut.net/shifter.htm
There ya go
T!mmy
12-28-2003, 11:04 PM
yea that's the one I followed but it doesn't tell me how much to tighten the bolt that the actual shift lever connects to
don't know if thats the right lingo but by shift lever I mean the part the knob connects to
thanks
T!mmy
12-28-2003, 11:07 PM
ahh I see it...it says 16lb ft
T!mmy
12-30-2003, 04:54 PM
k one more question about my install it's rubbing the top of my exhaust and I was going to just bend it down but since it was on the rubber hangars and all that it gave. How should I go about stopping the rubbing or bending the pipe/heatshield? C'mon Ricochet help me out :D lol thanks
T!mmy
12-30-2003, 05:43 PM
Ricochet...hellllooo? lol anyone for that matter
knorwj
12-30-2003, 06:18 PM
mine rubbed on the heat sheild also, I think it is unavoidable. I just cut the heat sheild off right behind the shifter. As an added bonus the exhaust pipe warms up my shift knob:iceslolan (cold steel shift knob and 10 degree weather NOT fun).
T!mmy
12-31-2003, 10:01 AM
lol "Automatic Shift Knob warmer..." I could see us making some money in that lol
Ricochet
12-31-2003, 01:39 PM
post pics..
T!mmy
12-31-2003, 02:42 PM
you've got to be shitting me...post pics? all it's doin is rubbin on the heat shield on the exhaust. And rattles when in neutral and the car is running.
Ricochet
12-31-2003, 02:45 PM
Take off the heat shield.. What brand short shifter is it?
T!mmy
12-31-2003, 03:10 PM
that no brander that I bought from kicker1_solo
T!mmy
12-31-2003, 03:14 PM
BTW the heat shield is welded on
BullShifter
12-31-2003, 04:52 PM
Whats rubbing, shifter, shift rod, etc? If it's the little nub(balance) on the shifter rod, then you trim/cut that off. Otherwise just bend the shit out of the way - shifter is way more important than exhaust.
T!mmy
12-31-2003, 05:12 PM
I believe it is the little balancer...lol it's kind of looks like a wagging tail. when you move the shifter left to right it moves too lol
maybe ya'll will understand ;) thanks
BullShifter
12-31-2003, 05:26 PM
http://www.imagestation.com/picture/sraid96/pcfc358d2f1571ef475a26f968443cf73/fa1fac93.jpg
There does that help? If it's the part(piece hanging down) circled in red, then you can chop it off or trim. . . Not the whole rod, just the piece hanging off.
closer view
http://www.imagestation.com/picture/sraid95/pe1c6dbe0c7e5510c198f0941312ce96e/fa1fa489.jpg
JDM00CivicEX
12-31-2003, 07:50 PM
I put my shifter in and it did the same thing, so i took it to a muffler shop they bent the pipe down so the shifter doesnt hit the piping. And now my shifter works smooth.
T!mmy
01-01-2004, 01:06 PM
Can they bend it without taking it off?
Sorry for my ignorance?
T!mmy
01-02-2004, 12:27 AM
Anyone? I guess I'll jsut call a local muffler shop tomorrow. thanks guys
NOBU-SAN
01-02-2004, 01:49 PM
WAIT!!! I just called a shop, being that I'm having the same issue. They told me most auto parts places, custom or not, have replacement hangers for the exhaust. It will lower it just enough to clear the exhaust. Good luck
Nobu
T!mmy
01-02-2004, 02:11 PM
hrmm I'm calling them right now
T!mmy
01-02-2004, 02:13 PM
yea he said it's possible but "I just have to bring it by for him to look at" damn lol
JDM00CivicEX
01-02-2004, 06:13 PM
All they have to do is pull the hangers for the piping. Thats it!!!
