Where is the flasher in a 94 Cutlass Cierra
wheels101
12-28-2003, 01:46 PM
Where is the flasher on a 1994 Oldsmobile Cutlass Cierra. I'm tryng to replace it but can't find it.
wheels101
12-28-2003, 01:50 PM
Where is the flasher on a 1994 Olds Cutlass Cierra located?
Bill V
12-28-2003, 08:36 PM
Remove the ash tray assembly to get to the flasher.
occupant
12-30-2003, 07:44 AM
should be near where the steering column meets the dash, and removing that lower plastic cover, the one that goes under the driver's half of the dashboard, and removing the ashtray, will help you find it...
it's a small round cylinder that plugs into what looks like a tiny fuse box...
torn132
05-03-2004, 10:57 PM
in the 91 it is inbehind the fuse panel in the glove box might help
Slade901
05-06-2004, 08:26 AM
On your 1994 OLDSMOBILE CUTLASS CIERA, the FLASHER is located:
Front seating area, driver side, under dash, mounted
on passenter side of steering column.
