I need help dropping the differentialdcw8653 12-28-2003, 12:05 PM I am in the process of changing the oil pan gasket. I need to drop the differential. I have removed the frame to differential bolts, the U-Joint, and the axle to frame bolts. Do I now need to remove the hub assembly and pull the axle from the differential to get it to drop. Any help would be much appreciated, thanks. dcw8653 12-28-2003, 12:05 PM This is a test vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
