1979 Skylarkicusawme 12-27-2003, 10:04 PM I need help getting a Buick Skylark started, it has a 260 V-8 I need to the the firing order, someone else replaced the plug wires and I want to verify they are in the right place. It is getting fuel and sparks through the wires but doesn't want to fire the engine. If anyone knows the firing order or where I can get this info it would be greatly appreciated. bill179 01-29-2004, 12:02 AM if it is the Olds engine big oil fill tube in front of engine and valve covers w/lots more than 4 bolts on each valve cover FO 1-8-4-3-6-5-7-2 cyl. #1-3-5-7 on driver side 2-4-6-8 pass. side i dont know if they go on in a certain order on the cap RABarrett 01-29-2004, 03:38 PM The order on the cap follows the distributor rotation, typically from the marked #1 on the cap. If you place your hand on the vacuum advance, curl your fingers as if to hold the distributor. This will indicate the direction of the rotation. If they curl away from the dist, use the other hand. Ray Automotive Network, Inc., Copyright ©2012
