Oil in Anti-Freeze
DL58
12-27-2003, 07:09 PM
Hello,
I hope someone can help me. I seem to have a brownish color looking oily substance in my radiator. I have flushed the system out and for some reason it has returned. I had a new radiator put in and still it has returned. Can anyone tell me what might be causing this? The truck does not overheat. Any advice would be appreciated
Twist'n-Wrenches
12-28-2003, 05:39 AM
Does your oil drop in level? If it does you could have head gasket or head problems. You did not say what engine is in your truck. If it is a 4.0 they are known for the right head gasket going. And worst of all the heads crack between the valves this I know as a fact as I replaced three heads two sets of gaskets before dropping a 5.0 in our Explorer. Good luck
DL58
12-28-2003, 03:29 PM
Thanks for your response. I checked the oil and it does not look like there is a drop in the level. I was under the impression that when your head gasket blows it produces a lot of white smoke. If that is the case I have not seen that either. How about the Trani? Could that send oil into the radiator?
Twist'n-Wrenches
12-29-2003, 05:21 AM
Yes there could very well be tranny fluid in the antifreeze as there is a cooler built right into the rad. If the cooler has a leak it goes right into the rad.
DL58
12-29-2003, 08:17 AM
Thanks for the information. I guess I will monitor the level of the trani now and see if it drops.
