95 grand am holding speed
esndmf
12-27-2003, 09:20 AM
hey
i have a problem trying to keep the same speed. the car accelerates fine and shifts through gears fine but when i try and hold my speed the car starts to shake. it stops when i leave off or push in tha gas. Its a 3.1l automatic with no overdrive. any suggestions would be appriciated!
Thanks
Mark
diamico1
01-02-2004, 03:29 PM
Hi there, I have the same problem when I hit 53mph and above. i've had 2 mechanics try to figure it out and nothing. Have tried to replace erg valves, coil,computer and still the same thing. I desperate this is a pain in the butt!!
They've told me that they would have no problem fixing it but just can't figure what's wrong with it HELP...
Jpit
01-02-2004, 05:53 PM
There is an item called the VSS(vehicle speed sensor) that controls the Torque Converter Clutch system within the tranny on our cars. Maybe this is the issue....
Jpit
01-03-2004, 08:17 PM
Also another thing could be the TPS(throttle position sensor) which is located on the throttle body. It senses the position of your throttle plate and sends the signal to your engines computer for proper fuel metering.
pAint
01-31-2004, 06:00 AM
My car would shake at 60 mph and also would stop when i would release or press the gas. Took it to a few mechanics, and they found nothing. Turned out it was my alignment cause all this trouble. Found that kinda weird, but it fixed the problem. i thought it was gonna be something expensive.
95_GrandAM_GT
02-05-2004, 11:41 AM
the only thing i think that it would be is the insterment cluster...have you got it wet? Because if that happened the same thing would happen...but it would also shift hard...I would hit like sixty, and it would do that...when i got it fixed i got it up to like 124 and it was running great...no problems of shakking or any of that...
