Questions about '90 Tegyellownsx 12-25-2003, 11:47 PM I have a 90 teg that I don't know much about. Can anyone tell me what motor is in an LS? it is a 5 speed hatchback which I bought for my wife. (She was killing the clutch in my NSX so I bought her THIS car). It has 135,000 miles and the records show that the timing belt has been changed @ 90k Do I have anything else that I have to worry about as far as regular maintanance? ( I expect that the water pump was done at the same time ) Thanks for your input. erinashley 12-27-2003, 02:58 PM i also have a 90 integrals. its the b18. its a 1.8. never ever let it overheat even a little... its real bad for blown head gaskets. as far as maintanance... my motor had 250,000 miles on it before i rebuilt it and i never had any major mechanical problems, other that the blown head gasket which was my own fault. just regular oil changes will keep it running forever. just make sure you keep up with that timing belt because it is not a non-interference motor. if you want any suggestions on how to build, or what yeilds the most horsepower for that engine, just let me know.. i got it all. Spectre927 12-27-2003, 04:54 PM B18A1, weaker than 92-93 ls which has 140hp and 126 lb/ft of torque. Yours is rated 130 hp @ 6000 rpm and 121 lb/ft @ 5000 rpm. HondaIntegraXSI 12-28-2003, 08:53 PM okay, take your car and performe a tune-up on it with a new clutch (for the misses), plugs, plug wires, distrib cap w/ rotor, motor oil, tranny fluid, cam seal, check your brakes and suspention. when you doo all of this, if you want to upgrade, now would be a great time, or you could put a new motor in it since you have the kind of cash you have (NSX), ya know... tran_nsx 12-29-2003, 05:18 AM don't forget the fuel filter, everyone seems to never write this down. ethier they don't know about it, or they forget to mention it. HondaIntegraXSI 12-29-2003, 08:21 AM yea, thanks tran. drill out the back side before installlation though. The outlet is .84 the size of the inlet, this will free up a couple horses across the board. tran_nsx 12-29-2003, 10:35 PM no prob :wink: fieroman87 07-09-2004, 10:16 AM is the B18 from a 92 integra an interference engine? stated above, someone mentioned that it's a NON-interference engine and warned about the timing belt. if it was a non-int motor, the timing belt wouldnt be an issue because the pistons would never come in contact with the valves if the belt snaped, so which is it? i'm looking to purchase an integra and the timing belt blew, so i'm wondering if it needs a new head (valves) to make it run again. thanks in advance, Arty erinashley 07-09-2004, 10:24 AM " just make sure you keep up with that timing belt because it is not a non-interference motor." read again.... fieroman87 07-09-2004, 12:26 PM oops, i didn't see the double negative, thanks for the heads up Arty erinashley 07-09-2004, 02:46 PM not a problem! hey, good luck with the G2 integra, and lemme know how everything goes. i just rebuilt my motor, and re stuffed the head... so if ya need anything lemme know! erinashley@rickymartinsvagina.com integralover 07-09-2004, 03:40 PM " just make sure you keep up with that timing belt because it is not a non-interference motor." read again.... just to clearify this a bit further. IT IS AN INTERFERENCE motor. this is when your timing belt goes the pistons DO run into the valves. in a NON-INTERFERENCE motor the pistons DO NOT run into the valves if the timing belt goes. kinda like in football when they call pass interference, the defender is interferring with the player before the ball is reached. that is interference ManOnTheGo 07-12-2004, 01:04 PM 90-93 tegs have interference engines. I have a 91 LS teg and my timing belt blew on the highway doing 85. The mechanic quoted me $2800 to fix the car saying that he'd have to remove the head and machine the parts. I spoke to some Acura mechanics and they said that 1 out of 10 luck out when their timing belts break. I took a chance and replaced the belt without removing the head. The car started up fine and is still running. It cost me $800 to replace all the belts and starter (different issue). Automotive Network, Inc., Copyright ©2012
