I need more consistant voltageRicochet 12-25-2003, 01:52 PM Hey guys, just wondering how I can get more electrical power in my car. When I turn on my turn signal, my revs drop about 100 rpm and back up, on and off with the signals, and I can hear my fuel pump lowering too with it, on and off. When I turn my headlights/fogs on the revs drop too, then slowly back up, along with turning on anything else like the stereo, heater etc.. Would a grounding kit fix/help this? Bigger battery or something? I'm looking to buy a grounding kit anyways, but will probably think twice if it won't do anything. crxlvr 12-25-2003, 02:23 PM the ground kit might help you out some, but have you considered running either a bigger alt, or even two batteries, one for your car stuff and another stand alone for like your fog's, and stereo. Ricochet 12-25-2003, 02:39 PM It's not a big enough problem where I'd buy another battery and a new alternator. Maybe it's just that my battery needs replaced because I'm pretty sure it's the same one since I bought the car in early 2000. It still read 12V though, but a new battery since almost 4 years ago def. wouldn't hurt low430 12-25-2003, 02:44 PM I would suggest getting an alt test, goto les schwabb or a mechanic shop they have these expensive machines to test batteries and they can hook it up and test your alternator and your battery for free in less than 2 min, its tight I had a prelude with low volts same problem as you I took it there and they tested it. turns out my alternator was going bad very low output, replaced it and fixed the problem... Tercel GTS 12-25-2003, 08:41 PM I'd look at the factory ground wire connection at the block, then look at the positive assembly of wires at battery, your problem is most likely going to be a bad connection at one of these, trying a different, not extra, battery may be a strong suggestion also. darkerdayz 12-26-2003, 01:29 AM i agree...i got my battery tested at Advanced Auto Parts because i was going through the same problem and it turned out that my battery only had .5 volts in it. Spectre927 12-26-2003, 02:11 AM It still would be good to get a grounding kit. Ive heard good things about them. Ricochet 12-26-2003, 01:58 PM Hmm, well I'll get a new battery first, then a grounding kit is def. my next mod on the list, and I'll let you know how it turns out in case u guys get the same problem. eckoman_pdx 12-28-2003, 07:38 AM Ricochet, are you running heavy wattage through a stereo system by any chance? If you are, I would suggest a capacitor...I know a few people was battery was going to hell early due to the power draw from the stereo...it made everything else work like crap, kind of like you discribed. I know a capacitor solves that problem. Anyways, I know it's unlikely and a long shot, but I figured I'd throw it out there. BTW, low430, you are from the Portland area, or the oregon/washington area, arn't you? I figured this because you side Les Shwabs. Speaking of which, if you went to HIN in Seattle this year, you would have seen a white prelude in the Les Shwab booth, with mad ice. I mean, 12 tv's in the car/trunk, including a plasma screen in the trunk, to name some of the things. That's my buddy's car, used to own a shop up there. He is sponsored by toyo tires, so his car is in the Les Shwab booth at a lot of shows. Anyway's, sorry Ricochet. I'm not trying to Hijack your thread here...lol Ricochet 12-28-2003, 02:52 PM I've got a 500 watt amp powering one 12" sub... :) Maybe I'll go buy a capacitor today for shits and giggles. gunnmen01 12-28-2003, 05:02 PM make sure your grounds are tight, and clean any corrision off the battery cables too gunnmen01 F23A4Racer750IL 12-28-2003, 09:17 PM get the Sun Hyperground Grounding system. i got it on my WRX and had it on my 99 Accord. Import Tuners dyno results showed it actually made more power. Automotive Network, Inc., Copyright ©2012
