Suspension
GtRider
04-16-2001, 03:35 PM
Does anyone know where i can order some lowering springs for a 1994 g20t (for cheap) in the states????
primera man
04-16-2001, 06:38 PM
Look though some of the other threads,"Suspension Questions for P11" that may be able to help you out a bit.
Buying cheap may not be your best option though, as you only get want you pay for and may not be what you want.
Look at getting a good brand of spring....Eibach etc.
kris
04-24-2001, 07:00 PM
I believe Intrax sells the cheapest. But I heard they drop your car lower than any others, and may be a little bouncier than the others. Then there is always the rice way to do it, and hack your springs. :)
Nismoboy1
04-25-2001, 10:11 AM
I know HKS and Intrax makes springs for your 94 G20t. HKS will drop you about 1.25" and Intrax will drop you about 1.75". HKS is of higher quality and maybe a better ride than the Intrax. Intrax is lower, cheaper but possibly more bouncier especially with stock shocks. I recommend getting aftermarket shocks at the same time with either spring, KYB AGX's are probably your best bet.
You can get both springs at www.nopionline.com
and the shocks can be had for cheaper at www.tirerack.com Good luck :)
ishydaflip
05-04-2001, 07:39 PM
I have a set of INTRAX springs which lower my 1991 Infiniti G20 about 1.75 inches. I drive in NYC which has many potholes, but I never bottom out like people may think. I am happy with these springs, but can be a little bouncy at times especially sitting in the front. They get rid of the ugly gap bet. the fender and rims perfectly. I had the EIBACH ones before these, but it didn't even look like I lowered the car. :licker:
poppy_morenito
06-17-2001, 08:16 AM
Did you get new shocks with the Intrax or are you on stock ?
zykotik
06-17-2001, 09:05 AM
www.digitalracer.com
ishydaflip
06-17-2001, 01:37 PM
I am using my stock shocks w/ those Intrax springs
poppy_morenito
06-18-2001, 08:34 AM
Originally posted by ishydaflip
I have a set of INTRAX springs which lower my 1991 Infiniti G20 about 1.75 inches. I drive in NYC which has many potholes, but I never bottom out like people may think. I am happy with these springs, but can be a little bouncy at times especially sitting in the front. . :licker:
Where else would you be sitting other than the front ? Or did you mean the front end bounces up and down some ?
I want my car to look lowered since I plan on getting 17's. What size tires are you riding ?
In NY it most be rough . I lived in Philly and never considered lowering because of the potholes ......
