How do I change the headlights on a 2001 SEJSheriff 12-23-2003, 01:16 PM Any information on how to change the headlight bulbs would be greatly appreciated. Thank you. Josh Markgase2000 12-24-2003, 01:56 AM pull the pins on top of the light assembly to release the light , gently pull the light assebly out of its home , on the back is a round knob thats you push and turn clock wise , be gentle its not very strong , gently pull the bulb out and put the new one in the same way you took it out , dont touch the bulb instead hold the backing of the bulb and put it in straight , then reverse everything to put it back together. Youll probobly need a alighnment after to make sure the lights are straight. Automotive Network, Inc., Copyright ©2012
