quick strut questionintegRS 12-18-2003, 09:54 PM hey i was wonderin if struts are really worth it? what exactly do they do...and how do they feel when i put them on? (tighter control, looser, less sensitive, etc) thanks Spectre927 12-18-2003, 09:58 PM Do you just drive around like a typical driver? Theyre a must if you drop your car, and yes they are nice to have. Tighter and handle better, especially if you spend good money. In another sense if you want to drop your car, then you should get a true coilover system which comes with them in it. BullShifter 12-20-2003, 08:17 PM Struts basically stop the spring from bouncing forever. Struts/shocks are just important as springs. Increased ride quality, increased handling performance, lees chance of shock fade which results in the shock usually blowing(seals go bad, fluid leaks) They will be tighter & more sensitive. Aftermarket shocks/struts are a must when lowering. Automotive Network, Inc., Copyright ©2012
