FS: BMW alternator repair NIB, Bosch + most 76-93KC Ron Carter 12-16-2003, 10:23 AM I can send you a German made regulator built for this Bosch alternator for $28 plus $3 for shipping. http://i12.ebayimg.com/02/i/01/00/f3/f2_1.JPG Fits all the following BMW models, E12 76-81, E21 77-83, E23 76-89, E24 76-89, E28 82-88, E30 84-88, E32 88-94, E34 89-93 No need to spend over $200 just to correct this maintenance issue. Alternator Regulators from Germany new in the box. They can wear into a grooved pattern and the impact of driving can make them vibrate out of the normal groove. Since the regulator has to increase output to jump the gap it does. You can clean up the slider rings with abrasive paper. You can get the brushes as a separate part requiring soldering skills or you can get a Regulator brush assembly for $70 retail at most auto parts store, or buy here. I sell only German made, the others are always suspect. Some instruction for changing: It is a very touchy installation and about 5% of the installation end in the ground link bent and the alternator not functional. You can remove correct and reinstall the regulator. The output must be 14.25 or higher on a Volt Ohm Meter not the dash gauge. Some hints on the regulator change. Replacing Alternator Regulator For those who work on their cars and have not had alternator problems, here is a simple action that should save you down-time and significant costs. Most alternators on German cars fail due to brushes wearing down (as they are supposed to) between 150k and 200K miles. Brush replacement is very easy -- it should not take over 20 min. and the brushes are attached to a new regulator. To replace regulator assembly -- back of alternator held in place with two straight slot headed screws. This has a round transistor mounted on the outside on Bosch alternators -- the other type, Valeo, is similar but uses different brushes. Pop the regulator out, after removing the screws. Fitting the regulator back is simple, but you must install it starting at an angle, to assure that the brushes compress when the regulator is flush with the alternator and the screws are tightened. You are now ready for 200K miles of alternator life. If you can change spark plugs you can change the voltage regulator. Will "NOT" work on E30 89-93, E36 91-96, these are made by Valeo. Later, Payment instructions: I accept all major credit cards payment through PayPal. Please use my registered PayPal and e-mail address. My PayPal ID is "kcroncarter@kc.rr.com" Shipping within 2 days. On checks shipping within 5 days of check receipt. Ron Carter 8301 NW Waukomis Drive Kansas City, MO 64151 Automotive Network, Inc., Copyright ©2012
