Re: Re: Re: 95 chevy low rough idle
Did you install a new ignition coil or a pick-up coil?
The pick-up coil is located inside the distributor...a faulty pick-up and mainshaft magnet will cause the problems you are having.
Remove the distributor and inspect it closely.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
