Is this Crankwalk?
eclipsekid
12-14-2003, 12:20 PM
I've done alot of searches on crankwalk and I've found tons of technical information about the causes of it and what to do (get a new motor). But I cannot find alot of information on the SYMPTOMS that are experienced when you first realize you have crankwalk. So far the only things I know is that it happens on turbo models (only?), happens when making a left and the clutch pedal sticks to the floor, and makes a horrible noise when it's happening. So my question is do I have crankwalk? Here is the skinny:
I have a 96 ' non-turbo GS eclipse. About two weeks ago, I was coming to a stop and as I normally do, I put my clutch in to put my car in neutral to drift to the stop. Well after I put my car in neutral, the idle got really low and sputtered a bit then it stalled out. It has been doing this kinda on and off (more off) since then. Sometimes when coming to a stop, and I engage the clutch and shift into neutral it will start to stall (get reall low in rpms) then recover itself to around 1k rpms.
Could this be just be some type of an idle issue (ICS, broken speed swtich, throttle body, etc.) And if so, how to fix. I've heard that it happens when you make a left turn and then the clutch sticks to the floor. This does not happen to me. Also, I do not hear anything unusual when it happens, just the engine shut off. I always make sure I have the propper amount of oil in the car and that it gets changed regularly. Also, I've noticed that my engine runs really cool, sometimes I will be driving for 30 mins. and the temp gage reads only slightly higher than when completely cold. I was wondering if somehow this might be a cause of my problem, since it only started happening after winter came around. Any suggestions/comments would be greatly appreciated.
Ryan
97GSTspyder
12-14-2003, 09:47 PM
hey dude i had this same exact problem...sadly it is a sign of crankwalk according to this page... http://members.shaw.ca/costall/1000Q/answers-terms.htm#whatiscrankwalk
as a result, my car is still in the shop getting repaired. i am suppose to get it back tomorrow though. had to get a new short block for it :( you should get your car checked out man cause those short blocks aren't cheap.
Steve
kjewer1
12-15-2003, 03:16 AM
Its very unusual to hear of a NT getting CW, since it doesnt even have the 4g63. I doubt it is CW, though the cluitch thing sounds like it. Its also possible that the clutch is just very worn, and the over zealous helper spring in the 2g clutch pedal assembly (should be the same as the turbo cars') holds the pedal to the floor. This can happen in the 2g turbo cars as well and is know to be a false sign of CW that has had many a poeple runing scared. ;) HAve that looked into before crying CW
eclipsekid
12-15-2003, 09:51 AM
Thanks for the replies. Kevin, my clutch does not stick to the floor. Maybe I worded it wrong in my post. Yeah, I just haven't heard of any non-turbo eclipse's experiencing this, maybe I'll just try driving around and just pull it out of gear w/o putting in the clutch (although this can be bad if done alot), and see what happens since the clutch thing seems to be the de facto sign of CW.
smokeurass
12-15-2003, 01:25 PM
Would you have a get a new motor to fix this even before it happens? Cant you just replace the crankshaft?
97GSTspyder
12-15-2003, 03:50 PM
if your car has a lot of miles, it could possibly be the fuel filter. it could be pretty clogged up which would cause stalling. you might want to think about replacing it. they're fairly cheap.
eclipsekid
12-15-2003, 06:52 PM
Thanks for the suggestions guys. Yeah, I'll prob check into a new fuel filter since the car has 97k miles on it, can't hurt. I found this site, wonder if this is the root of my problem.
http://members.shaw.ca/costall/1000Q/Frameless/answers-problems.htm#Mycarstumbles/diesduringbraking (http://members.shaw.ca/costall/1000Q/Frameless/answers-problems.htm#Mycarstumbles/diesduringbraking)
kjewer1
12-16-2003, 03:22 AM
Since your original post says this:
I guess you could say you worded it wrong ;) :icon16:
eclipsekid
12-16-2003, 07:29 AM
Yeah sorry 'bout that, I guess I did word that kinda wrong, I was talking about the SYMPTOMS that ppl experience if they have crankwalk, and not about my own symptoms. BTW, I took the car out yesterday, and I did notice that it would stall, when I took the car out of gear into neutral without using the clutch. Doesn't CW have to do with the clutch? If I didn't use the clutch at all and it's doing this, does that rule out CW completely? Thanks again.
T38
12-16-2003, 08:09 AM
Seems to me I saw something the other day describing a vacuum problem that caused similar problems (stalling/low rpm) when braking with the engine at idle. I can't find the article now (figures...), but does this sound familiar to anyone else?
97GSTspyder
12-16-2003, 11:43 AM
all right i pulled out the mitsubishi eclipse repair manual haha...according to the manual there are a few reasons why your car would be stalling...
1. idle speed incorrect
2. fuel filter clogged and/or water and impurities in the fuel system
3. distributor components damp or damaged
4. faulty emissions system components
5. faulty or incorrect gapped spark plugs
6. faulty spark plug wires
7. vacuum leaks
mauri
12-16-2003, 03:55 PM
ive got a 95 eclipse with automatic transmission, and every time the engine its gonna change to another gear(speeding up) its makes a loud crank sound, i really dont know what it is, im about to open all the engine and look for everything in there, its gonna take a while, but i really like this car and i dont want to get rid of it, any comments before i srewup this car, new engine perhaps or do i have an option fixing the engine?
mauri
12-16-2003, 03:56 PM
need 4 help
eclipsekid
12-16-2003, 05:55 PM
Thanks for the info 97GSTspyder. I think the first thing I will try is maybe putting some gas treatment in since that would be the cheapest. If that doesn't work, I'll prob just take it to a mechanic who knows import cars (I certainly don't, I just got into cars about 5 months ago, I used to be a Jeep man). Hopefully it's nothing too serious, and I will definately post the fix as soon as it comes about.
NeonblueEclipse
12-16-2003, 06:21 PM
check the tranny fliud, i dont think it'll be a problem with your engine
at most maybe a busted tranny that'll have to be rebuilt or replaced
but its better than engine problems
97GSTspyder
12-16-2003, 10:16 PM
yeah gas treatment may help you out a bit..along with a new fuel filter. also, try not to drive your car much on a low fuel tank because that's where all the debris and shit sits and will get sucked up and make the car not run as well. hope this helps ya out
smokeurass
12-17-2003, 10:27 AM
I would like to make this a mod before a repair. Would i only have to replace the crankshaft, or the bearings too (even before crankwalk starts)?
---edit---
never mind, i got it...
kjewer1
12-17-2003, 11:10 AM
More often than not, changing out the bearings/crank doesnt fix the problem. But I have seen it work, for some length of time anyway. I wouldnt suggest it for a long term solution though. At the very least if you are going to stay 7 bolt have a reputable, DSM only shop build the motor. They know the tricks to help prevent CW during the buildup.
smokeurass
12-17-2003, 12:54 PM
Well, what can i do...cuz i tend to have bad luck with a lot of things, i dont wanna mod the shit outa this thing and then have to buy more motors....
GSX88
01-03-2004, 06:00 PM
How common is crankwalk in turbos. I was thinking about getting a gst or gsx but my brothers friends gst was a piece of trash. I dont know if it is just his car or if all of them are like that
kjewer1
01-04-2004, 03:35 AM
95-96, maybe 1%.
soyee7
01-04-2004, 04:21 AM
how much is it ussually to have a dealer change the crankshaft bering
kjewer1
01-04-2004, 08:01 AM
In my experience the dealer will try to replace the short block (2700 parts, 1300 labor, YMMV) especially if the car is out of warranty. ;) IF they did change just the thrust bearing, I bet you would be looking at roughly 5 hours labor.
