batterySoyo 12-13-2003, 05:45 PM http://www.planetperformance.com/vehicle.search/?searchtype=5d&sortorder=ADAA&urlsubcategory=Electrical&productcategory=Batteries&sf1=MAZDA&sf2=1991&sf3=RX7&sf4=Search+By+Vehicle+Application would this be a good battery to use in a battery relocation to the passenger cargo box? and can anyone give me some links to where I can figure out some info on making a box to hold it in? Entreri33 12-14-2003, 04:50 PM You must use an optima (or like type) battery. A standard battery like from Autozone or Sears will release TOXIC fumes into your car. But Optima batteries rock as far as reliability. They far exceed a diehard or interstate. SR20DETpower 12-14-2003, 07:20 PM my brother has a red top Optima in his car, its junk.....The type is what you are looking for, but if your going to do it, do it right and get the stronger yellow top battery, that is a badass battery right there. J-Rat 12-15-2003, 12:44 AM Hope your not trying to drag race (legally). If you are, order a cutoff switch while your at it. Let me guess, your relocating your battery because that weight in the back is going to make your car corner like its on rails? Soyo 12-15-2003, 01:05 AM I'm not planning on racing, I'm relocating to open up space and open up air flow a bit, and put a little more wieght on the passenger side to balance it a bit better once I hop in... thats all if I even do it... I'm kinda thinking about it, but I don't plan on working on my car much untill it warms up! haha just checking up on things just incase so is this what your talking about? http://www.dcbattery.com/optima_yellow.html whats the difference in the d75ou and d75os? and would both be ok to use inside the car? like I said, I'm still trying to figure all this battery stuff out :loser: Jims5543 12-23-2003, 09:14 AM Hope your not trying to drag race (legally). If you are, order a cutoff switch while your at it. Let me guess, your relocating your battery because that weight in the back is going to make your car corner like its on rails? When we corner weighed my car it was 40 lbs. light in the right rear corner. At the time I have a 10 lbs dry cel in the front battery tray. Guess where my battery is now? Right rear. Now it corners mad fast yo! J-Rat 12-23-2003, 02:25 PM I am sure it does...:) Soyo 12-23-2003, 07:44 PM that pretty much tells me nothing at all, I don't care about that, I am just trying to figure out what battery you all would suggest, right now I'm not relocating it but I am going to be getting a new battery soon I believe Jims5543 12-24-2003, 12:58 AM Actually you asked what to use for inside your passanger compartment. You can run your battery in the passanger compartment if you use this. Its a Moroso Battery box. its about $100. At summit racing. http://static.summitracing.com/global/images/prod/large/mor-74050.jpg Vendor: Moroso Performance Products, Inc. Product Line: Moroso Battery Boxes Material: Polyethylene Finish: Blue Length: 10 1/2 in. Width: 13 in. Height: 9 1/2 in. Total protection for your battery. Blue, 10 1/2 in. deep, 13 in. wide, 9 1/2 in. tall, battery box When you stuff your battery in a Moroso sealed battery box, you can locate it just about anywhere you want on your vehicle and not worry about water, dirt, dust, etc. ruining it. Accepted by the NHRA and IHRA, the tough polyethylene box has an airtight lid with a foam gasket to keep battery gasses from entering you car's interior (six quick-release fasteners keep the lid on tight). The box comes with a vent tube, battery hold-down with 3/8 in. steel rods, rubber cable clamps and grommets, and mounting hardware. Sold individually. Jims5543 12-24-2003, 01:00 AM And quite honestly. I cannot understand what to big deal is over the Redtop batteries. Your Altenator is what supplies power once the car is running. Not the Battery. I would be more concerned about getting my hands on a FD Atlenator. J-Rat 12-24-2003, 02:14 PM Already got one...:) B_Rock 12-24-2003, 07:46 PM i have my battery relocated to that spot. i have the "miata racing" battery. i dont know the exact numbers on the battery but my car runs great on i and the battery fits nicely with no cutting. i also have the fuses for my stereo in there as well. Automotive Network, Inc., Copyright ©2012
