Manual Boost Controller???!?!dohcgst 12-13-2003, 11:59 AM Can someone help me... i would like to know how easy or hard it is yo hook up a manual boost controller on my stock turbo? Thanks snickers 12-13-2003, 06:20 PM easy one end goes to wastegate actuator and the other to a pressure side of the turbo. Either the lower i/c pipe nipple or tee the bov. Matt ps. halman mbc is really good BoostedSpyder 12-13-2003, 07:54 PM have you tried to remove the BCS restrictor? if you have, that is about the same dificulty level as changing it all together, and if not, do a search on it or look it up on www.vfaq.com dohcgst 12-14-2003, 10:38 AM boosted i dont understand what you said... dont look it up anywhere? and no i havent tried to remove the bcs BoostedSpyder 12-14-2003, 09:58 PM http://www.jumptronix.com/2g_go_faster/Faqs/WasteGateSolenoidRestrictionFAQ.htm this is what it is... it is right between your intake and your radiator, under the radiator dump container. it will add a couple of psi of boost, but realize that you NEED to get #1 priority a BOOST GAUGE and a BOV. the gauge that is in the dash is useless, it is a reading that the ecu calculates, and it doesn't even have any #'s on it. in order to know what you are doing, you need a real gauge. there are mechanical and electronic, depending on how much $$ you want to spend. if you do a bit more reasearch, this is always 1st on the list. the factory BOV is plastic, and it will only hold 15 psi and start leaking at 12 psi. 1g stock is a cheap option, GReddy type-s is more $$. whatever you choose, you have to be able to dump the air back into your intake in order for your ecu to run the car properly. you can also look into intercooler piping, dejon tools makes cheaper pipes, and you can buy them with any flange to take any BOV, and GReddy makes a kit as well. before you do all this, get an Injen intake pipe, and remove your stock crap. i suppose you could do your exaust and downpipe up front as well. there are many to choose, just make it 3" and you will never need to replace it. Apexi n1 and greddy evo are nicer exausts, but you can build a custom 3" exaust for less $$. RRE (http://roadraceengineering.com) makes a good downpipe, and are also a good place to see how to properly tune your ride. anyway hope that helps... check my ride thru my sig, that is one way to do it... Automotive Network, Inc., Copyright ©2012
