12-11-2003, 11:16 PM
pontiac grandprix speed limiter (97's)only
can somone tell me how to get rid of the top speed governer for my (97) pontiac grand prix, iv don way to manny mods to list(it's fast as hell) but i cant go over 115,or wher ever it is, (but rice burners can).
and yes I have a reprogramed pcm (DHP) even tried two diferent pcm's to make shure it wasent bad. crank sensor relearn dosent make a diference either(people at DHP)!
It seems that 97's are the only GP's that dont respond tho the pcm speed cut out eliminator so I want to do It manually. If anny has had same problem let me know, of if you can solve my problem you have my respect. Goldschlage@aol.com
12-12-2003, 07:05 AM
Re: pontiac grandprix speed limiter (97's)only
That is funny, I got rid of the speed limit with the ECU(PCM) reprogrammed. Check because even tought they reprogrammed yours they must explicitly get rid of the top speed. I have been able to push my GTP all the way up 138mph racing a Cayenne S. And not many mods but sure I changed the ECU(PCM) programming to get rid of the speed ceiling.
12-12-2003, 10:47 AM
Re: Re: pontiac grandprix speed limiter (97's)only
Are you 100% SURE it's a DHP PCM? If so, then email them and ask them what the deal is. I know the guys at DHP, they should be able to help you.
www.digitalhorsepowerinc.com
As far as removing it manually..there is no way to do that. There is no mechanical part that limits speed.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
12-12-2003, 11:54 AM
i know a kid that has a 97 gtp. it used to be an undercover car. it is all stock, except for the police interceptor chip in it. he hit 163mph. i've got that crazy speed limiter too, and can only go 126mph.
12-12-2003, 11:56 AM
where can you take the car to get it reprogrammed and how much does it cost?
12-12-2003, 12:30 PM
 ... www.digitalhorsepowerinc.com or you can buy one of their PCMs from www.3800performance.com
If you want to have one of them reprogram it in person, you better be ready to drive to Chicago or Detroit, or pay them to come to you.
Just so you know, DHPv2 will be out this spring...and it comes with a few improvements. I'd wait till then..but that's just me.
There are other PCMs out there that you can buy (C-YA Racing, GPS), but if I remember correctly, they just ripped DHP's code and made a couple changes. That's why one of the new features of DHPv2 will keep people from stealing the modifications they made.
Also be aware that when you have the PCM reprogrammed, you HAVE TO run premium unleaded gasoline.
12-12-2003, 07:41 PM
Rom,
I dont think your right about any of that. First off, GPS was out before DHP existed so how did they steal DHP code.
From what I understand about the CYA PCM he has partnered with a retired GM employee that use to write the code for GM. I dont think CYA needs to copy anything
BTW, I own both PCMs and you cant go wrong with either one.
Tim
12-13-2003, 04:02 PM
Well mine was done by a guy that knows about this thinnhs on the local GM Dealer. The usual cost of PCM reprogramming is between 250 and 400 bucks. Depending on the mods they perform on it
12-14-2003, 11:33 AM
Originally Posted by Ripn12s
Rom,
Tim
I'm just going off of what I gathered from past posts that I read at www.clubgp.com
12-16-2003, 09:11 AM
Tell me what you have done? Got rid of the ceiling.
12-16-2003, 09:12 AM
Rom do you know what the improvments are? What they changed from V1 do you know?
12-16-2003, 11:20 AM
I do not know the changes that have been made yet. I only know the few snippits of info that Charles from DHP posted in a thread on Club-GP.
He's claiming it will be done by spring. I hope it is...I'm gonna need mine dyno-tuned.
12-16-2003, 12:36 PM
how do you guys read your codes. don't you take it to like autozone to have them read it. can't you reprogram the speed limiter with the same computer that they use there?
12-16-2003, 02:21 PM
No..that's a code scanner, not a programming device.
12-16-2003, 02:32 PM
Banned
DHP V2 will require more mods then the current V1
It will offer updated codes as well as a Flash Gaurd so the dealership cannot accedentaly reflash your computer....It should be good for those with more mods!
