Re: 1996 caravan - sudden shuddering
Before you spend all that money, I took someone's advice and had the transmission flushed and replaced with the correct fluid. It completely fixed the problem. I found out that on this transmission if you use anything other than the mopar 7176, it will cause the trans to shudder like that. Whatever you do, dont let them put the dextron or any other fluid in, make sure it's the correct fluid. Hope you have as good of luck as I did.
