air to fuel ratio guage install!?
Google
Web AF
JGTP94
12-10-2003, 09:43 AM
ok i have a 94 GTP and i want to put an air to fuel ratio guage in it does anyone know howto do this or have any of you dont this before?? any infor helps !
thanks
kilroypr
12-10-2003, 08:51 PM
Well, the ECU(a.k.a PCM) is the one that controls the mixture ration. THe only way to get what you want(to my humble understanding) is getting the reading from the PCM directly. I do not know how this is done, but is the only sensible way because if not then you should have to install a sensor on piston 1 and this sensor will read the gas and air relative quantities at the piston and then give you a reading.(This is not really easy to do, the PCM reading is the same and safer). I do not have the deatails how is it done from the PCM tought :(
JGTP94
12-10-2003, 11:45 PM
ok i was told that i hook the green wire up to the 02 sensor and there is a black wire 2 white ones and a gray one. But which one is the signal wire???
kilroypr
12-14-2003, 09:54 AM
I do not know. I have the shop manuals for the 98 Pontiac. Mayve if you send a private message to The Burning Rom or Ripn12s they might have the information that you are looking for.
Google
Web AF
