Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 12-09-2003, 09:30 PM   #1
HONDA-CYCLES
HONDA-CYCLES Normal reputation
Question 98 tahoe "bump & clunk" drivetrain problem
First post!
My 98 Tahoe has what they call a Bump & clunk in the drive train. It is most noticeable upon take off and when you come to a complete stop. Taking off, if you nurse it slowly it won't do it. It has 94k nearly all highway and is still very tight in every other way. The U-joints were just replaced. Any help please?? Thanks Tom...
HONDA-CYCLES is offline   Reply With Quote
Old 12-10-2003, 07:18 AM   #2
sagbels
sagbels Normal reputation
My '95 2Dr 4WD just started doing the same thing - and like you, the u-joints were just replaced also (like a week earlier). I am keeping my fingers crossed that it may be a bad u-joint (not likely). I've got an appointment at a garage Thursday hopefully they can find the problem.
What worries me is; a friend of mine had a '99 escalade that had the same problem, his dealer suggested it was 'play' between the tailshaft of the tranny and the yoke of the driveshaft and that it is a common problem. I will try to let you know what I find out.
sagbels is offline   Reply With Quote
Old 12-11-2003, 09:15 PM   #3
HONDA-CYCLES
They have also told me about "extra play" in the Yoke but that is a common problem and does not cause any other problems. I know there has to be a cause for this other wise why wouldn't everyones do this? Thanks Tom...
Old 12-12-2003, 01:26 AM   #4
Bryan C. King
Bryan C. King's Avatar
Bryan C. King Normal reputation
Send a message via AIM to Bryan C. King
Mine does the same thing, I repled the u joints, think there is something loose in the rear end.....
Bryan C. King is offline   Reply With Quote
Old 12-13-2003, 08:20 AM   #5
99ssconv
99ssconv Normal reputation
a temporary fix is to remove the drive shaft and install a small amount of GM special lubricant to the splines on the slip joint, should last 6 mths to a year depending on driving habits. the cause is the slip joint binding on the trans tail shaft causing the noise and bump feel. you can also use a brake lathe bit and clean the grooves between the splines on the trans output shaft and the drive shaft slip joint if you dont want to spend $50 for the can of GM special lubricant. the can will last you forever and takes just the removal of the driveshaft and your done.
99ssconv is offline   Reply With Quote
Old 12-13-2003, 08:49 AM   #6
HONDA-CYCLES
Re: 98 tahoe "bump & clunk" drivetrain problem
Thanks! I'll try that this week and let you know. Also thank-you for taking the time to answer. Tom...
Old 12-14-2003, 07:40 AM   #7
sgt.rock
sgt.rock Normal reputation
Re: 98 tahoe
Originally Posted by HONDA-CYCLES
First post!
There has been an update on the rear end gear oil. Call your dealer about it. My 99 was doing it and when i took it in they had just got the notice.
sgt.rock is offline   Reply With Quote
Old 12-15-2003, 08:24 AM   #8
wofton
wofton Normal reputation
I have a 99 Tahoe with 33370 miles on it. The clunking noise you describe is the same in my vehicle. Have not had it diagnosed as of yet. Still trying to recoupe from my busted transmission which happened a week ago. Has anyone else had their transmission go bad at 33370 miles?
wofton is offline   Reply With Quote
Old 12-15-2003, 11:32 AM   #9
wofton
Re: 98 tahoe
First post!
My 99 Tahoe had the same problem. Just came back from Chevrolet Repair. My problem was fixed simply by lubricating the slip joint. There is a Bulletin out on this problem.
Old 12-20-2003, 08:11 AM   #10
PowDuck
PowDuck Normal reputation
What's so "special about the GM Special Lube? What type of lube is it? gear oil type, grease type, ATF type?
PowDuck is offline   Reply With Quote
Old 12-22-2003, 02:15 PM   #11
wofton
My bump and clunk on my 99 Tahoe is back. GM lubed the slip joint. It was ok for a couple of days, but the noise is back again.
Old 12-25-2003, 08:49 PM   #12
TA2000LE
TA2000LE Normal reputation
Re: Re: 98 tahoe
I have a 2000 Tahoe Limited, I had the same problem. Took it to chevy they said "the slip yoke just needed to be lubed," which temporally fixed the problem. A week later, with about 42000 miles on the car, the WHOLE tranny needed to be replaced. Havent had said bumb/ clunking noise when I come to a stop since....
TA2000LE is offline   Reply With Quote
Old 12-26-2003, 12:03 PM   #13
wofton
What was your problem with the tranny? Did they fiond a bad sun gear?
Old 12-30-2003, 05:05 AM   #14
TA2000LE
I didnt ask about the tranny. All I know is that when I took it in I couldnt shift into reverse and they dropped the pan on the spot and it was filled with metal. If it was a bad sun gear, there wasnt much left of it. hehe
Old 12-30-2003, 12:10 PM   #15
tenth_rc_Racer
tenth_rc_Racer Normal reputation
Send a message via AIM to tenth_rc_Racer Send a message via Yahoo to tenth_rc_Racer
I pulled my driveshaft and im going to lube the slip-yoke with Almaplex industrial lubricant made by Lubrication Engineers out of Fort Worth, TX. I got this at work and it is supposed to be one of the best lubricants ou there for water resistance, heat resistance, rust and oxidation inhibited, and has Almasol in it! Ill let everyone know what happens.
tenth_rc_Racer is offline   Reply With Quote
Bookmarks
Google
Web AF
