Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 12-07-2003, 05:29 PM   #1
Jeff_sr
Jeff_sr Normal reputation
Exclamation dome light turns off radio & door locks
MY dome lights, radio & door locks have always worked. Starting last night, Opening the door or activating the dome lights by any switch, is causing my radio to turn off AND loose it channel MEMORY. It causes relay chattering behind the radio and the door locks chatter. The dome lights do NOT come on (usally) during this malfunction. It acts like a bulb has a dead short (almost impossible).
All fuses are good, however, there is no power going to the dome light fuse (either side). All other fuses show 12.1 volts. There is no change between engine running or keys in my pocket. I need schematics for this 1995 caravan and help, Thanks!
Jeff_sr is offline   Reply With Quote
Old 12-16-2003, 09:45 PM   #2
daveyhouse
daveyhouse Normal reputation
Hello,
I had the same problem with my 89 voyager.
y problem was a fuse they were all runnung off the same fuse. The fuse was good, but the connection for the fuse was sloppy and losing contact. Find the fuse for the mentioned device pull it out and with a light tester probe or something small in that fashion bend the tabs a little closer so that the fuse fits snug and tight
Hope this helps,
Dave
daveyhouse is offline   Reply With Quote
Old 12-16-2003, 10:23 PM   #3
Jeff_sr
Thanks for your input. I have odered the factory repair manual. The common denominator to all this is the "Body Computer". There are service bulletins about this, that I am waiting on too. So I wait a week for the manual.
Bookmarks
Google
Web AF
