Clutch Problems *Need Help*
Dru998
12-07-2003, 05:12 PM
Hi, I am having a problem with my clutch. There is absoulety no resistance in the pedal. It will go to the floor with a little push of the finger and stay there. I had thought that it might have been the master cylinder, so I replaced it. Still same problem. I am not sure where the slave cylinder is located, but I think I have found it. There is a big puddle of what looks like brake fluid under it. I had the slave cylinder replaced about 1.5 years ago so I assumed that it must be the master. Has anyone had this problem before? If so how was it fixed? I am thinking of replacing the slave aswell. This is where I think the slave cylinder is located. Its a small cylinder looking thing mounted to the Transmission. I t has 2 bolts on either side with one big line connected to it. And a rubbery thing at the end. This is where the fluid seems to leak from. Thank you for any and all help. It is greatly appreciated :D.
spitz7985
12-08-2003, 01:32 AM
yup, its the slave. you can replace it very easily, and they're dirt cheap.
that "rubbery" think is the bleeder. it might have just twisted loose some how. you can take off that rubber cap- check to make sure that valve is tight, its just a nut-use a wrench. if it is tight and it's still leaking, you can replace that yourself in under an hour.
