no heatjststrd 12-06-2003, 08:37 PM I have a 1991 riviera. I went to work in the morning the heat worked. When I went home only cold air would blow out of the vents. Any one have any suggestions? I looked for a heater control valve but could not find one? hopefully not an expensive fis and someting i can do myself? biaggio 01-14-2004, 04:06 PM I have the same problem, it just happened this morning. It is 0 degrees here in NY too. Have you found out what the problem is? Thanks. Peter Licowski 03-01-2007, 10:23 PM I have the same problem, it just happened this morning. It is 0 degrees here in NY too. Have you found out what the problem is? Thanks. Did you ever find out what the problem was? My 91 just started that a week ago. ekimnamesseem 11-19-2007, 02:42 PM try checking your coolant level. I had the same problem and my coolant level ended up being low. HotZ28 11-22-2007, 01:48 PM This thread is nearly 4-years old!http://img326.imageshack.us/img326/4093/threadclosedga9.gif Please read: Posting in Closed or Outdated Threads (http://www.automotiveforums.com/vbulletin/showthread.php?t=635175) Automotive Network, Inc., Copyright ©2012
