Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mitsubishi > Montero/Shogun/Pajero
Old 12-05-2003, 09:15 AM   #1
BARNES523
BARNES523 Normal reputation
Unhappy 97 Montero -hold Light On
I don't have a manual, so I have no idea what this HOLD light means.
Yesterday, I had to unscrew several parts of the dash , ashtray and glove box to get to my stereo's serial number so the dealership could give me the anti-theft code. I am now wondering if I knocked something loose??
BARNES523 is offline   Reply With Quote
Old 12-17-2003, 09:24 PM   #2
MonteroNewbie
MonteroNewbie Normal reputation
Re: 97 Montero -hold Light On
This is verbatim from the user manual:
A/T mode changeover switch -
According to the road conditions, set the switch at the "Normal" or "Hold mode" for normal driving or for shift stage hold driving.
Each time you press the switch, the "NORMAL" AND "HOLD" will switch alternatingly. The "HOLD" indicator in the instrument panel comes on or off.
(this is what you see, right?)
Normally, drive your vehicle in the "NORMAL" mode where the switch is not pressed. (The "HOLD" indicator goes out)
NORMAL
for normal driving
HOLD
select the "HOLD" mode when starting your vehicle on a road surface slippery from snow or the like, and the vehicle will start smoothly. If you start your vehicle with the selector lever in other than the "L" position, the vehicle starts in second gear.
Hope this helps
MonteroNewbie is offline   Reply With Quote
Old 01-16-2004, 10:41 AM   #3
ajbringle
ajbringle
there is a button on the dash right under the rear defrost button that says a/t on it... thats the button that engages "hold" which basically puts you in 2nd gear from a start
ajbringle is offline   Reply With Quote
Old 02-13-2005, 08:00 PM   #4
jimmypodunk
jimmypodunk Normal reputation
Lightbulb
Ingenious. This is a usless switch. Sounds like you can accomplish the same thing by putting the transmission into second gear. Just ignore the light. Sounds like it's not worth the time or money to fix.
jimmypodunk is offline   Reply With Quote
Bookmarks
Google
Web AF
