I need to know the location of IAT on 98 neonjamesja 12-05-2003, 02:27 AM I am wanting to place a resistor in my IAT sensor to see if it will increase proformance but i do not know wear the sensor is located i know that it is on the intake manifold but i am not sure what it looks like or what numbers it has on it any help will but gladly taken. Thank you, Cpl Joashua A James Semper Fi USMC Sluttypatton 12-10-2003, 04:55 AM This should have been posted in the Neon forum, you would have recieved a response much more quickly that way. The 95-96 Neons had seperate IAT and MAP sensors, but 97-99 were changed, and had a combined IAT/MAP sensor. The location differs between SOHC and DOHC motors. Before you insert a resistor in the IAT's circuit, keep in mind that you are doing the same to the MAP. I have no idea what implications this has, as I haven't ever been inclined to do so. Good luck but I have a feeling that the result will be unsatisfactory to you. The SOHC position is http://files.automotiveforums.com/gallery/watermark.php?file=/503/63345SOHC.jpg The DOHC position is http://files.automotiveforums.com/gallery/watermark.php?file=/503/63345DOHC.jpg Credit goes to Haynes manual's for the pictures. Automotive Network, Inc., Copyright ©2012
