Temperature gauge
T!mmy
12-04-2003, 02:30 PM
Temperature gauge is not working. Just stays at the vey bottom.
Where is the connector for the temperature gauge on my engine? (98 civic ex, d16y8)
thanks in advance
T!mmy
12-05-2003, 09:41 AM
:feedback:
Ricochet
12-05-2003, 03:40 PM
Maybe it's just running really cool :)
I really can't help you, but I think the thermometer may be busted or your gauge is just stuck/not plugged in..? Your thermo is right above the tranny somewhere on the block. Well if somebody answers you we may both learn something..
T!mmy
12-08-2003, 09:02 AM
no more thoughts? anyone?
T!mmy
12-08-2003, 09:31 AM
Also one other thing I've noticed...it does move a little...when I start the car it comes up like 1 cm. but that's it. Hye do you think you can get me a picture of where the connector is on the engine?
Thanks in advance
Brian
BullShifter
12-08-2003, 05:53 PM
At idle, a 4-banger honda will take 10-15 minutes to heat up to "normal operating temp".
There is a coolant temp. guage sender located directly under the distributor housing. There are also thermosensors/switch & a coolant temp sensor located on the back/side of engine.
These aren't from the correct engine, but will give you an idea of the placement. www.helminc.com for a manual.
http://www.binghamtonlife.com/manual/2gsm/images/91-10-7.jpg
http://www.binghamtonlife.com/manual/2gsm/images/91-10-3.jpg
http://www.binghamtonlife.com/manual/2gsm/images/91-23-94.jpg
