can i fix an AC compressor?mike&susan 12-03-2003, 10:12 PM my AC compressor went, I need a new one, but my AC doesnt work anyway. i only need the compressor for the belt. (puttin a non AC belt wont work.) is there anyway i can fix the compressor, or do something disconnect something, or anything so i dont have to replace the whole compressor? i have an 87 cutlass ciera 2.8 thanks... shekky 12-04-2003, 05:10 PM if the compressor doesnt work it should just spin freely. if you dont care about having a/c, then just leave it. it only puts load on the system when the clutch is engaged. mike&susan 12-04-2003, 11:03 PM it spins freely, but sometimes it makes a loud like whining noise, and it smokes. i dont think theres a load on it, i dont use the air. shekky 12-04-2003, 11:34 PM you could just pick up a used on from a wreckers. 3 bolts and its on. takes a half hour in your driveway. bustedratchet 12-05-2003, 06:27 AM Does it only make noise in defrost mode? Compressors will turn on in defrost. If this is the case unplug it. Automotive Network, Inc., Copyright ©2012
