Need info on B16 motor swapautorecess 12-03-2003, 08:40 PM Im bout to cop a 1st gen b16... Its goin in my 91 integra. I want to know what I will need to complete this conversion! Engine mounts? wire hareness? shift linkage? ecu upgrade? vtec hook up? YOU GUYS GET THE IDEA! I need answers! Thepeug 12-03-2003, 09:16 PM Check out the civic swapping guide at the top of the 92+ civic forum. It's got information on most swaps for civics and integras. salbaje 12-05-2003, 01:32 AM just change longblocks your tranny, mounts, linkage, harness you can reuse autorecess 12-08-2003, 09:23 AM just change longblocks your tranny, mounts, linkage, harness you can reuse What your tellin me is the only thing that I can reuse is the wire harness? what do you mean by change your longblocks your tranny? Are you sayin change my tranny mounts? Also can use some of the same parts from my 91 acura... clutch? (ACT 6puck street/strip) DC sport headers? MSD ignition system? Thermal exhaust stainless cat-back? Ps. What about my ecu?? -or- Vtec hook-up THANKS FOR THE :2cents: I REALLY APPRECIATE IT GUYS !!!! crxlvr 12-08-2003, 09:30 AM all you would need to buy would be the head of the b16 and a new ecu, then you will have an LS/Vtec everyone loves, unless your bottom end is messed up. after swapping the heads, you just need to run 4 wires to your ecu to activate vtec. you can keep your harness, engine mounts, linkage, etc. autorecess 12-08-2003, 09:34 AM all you would need to buy would be the head of the b16 and a new ecu, then you will have an LS/Vtec everyone loves, unless your bottom end is messed up. after swapping the heads, you just need to run 4 wires to your ecu to activate vtec. you can keep your harness, engine mounts, linkage, etc. My bottom end is TOAST! So now what? salbaje 12-10-2003, 02:44 AM You can use all the parts of your car now. just change the motors. clutch yes msd yes plug wires yes etc etc as for vtec you'll need to use pr3 or pw0 ecu and need to wire in vtec wires. Or you can use an msd rpm activator to activate vtec Automotive Network, Inc., Copyright ©2012
