99 blazer highway moan...?frankjc 12-03-2003, 01:24 PM in my 99 blazer 4wd automatic,i get this moaning noise when i hit about 50-55mph. it seems to be coming from the right front underside area. sound familiar anyone? Glenn Peters 12-03-2003, 07:37 PM search for - humming niose r/f, posted by glenn peters. Thats me. frankjc 12-03-2003, 09:13 PM i checked it out, but didn't see any solution.... have you figured it out yet? a guy i work with took it for a ride, and his first guess was the wheel bearing/hub. we couldn't get it up to 50-55 mph, because it was rush hour, he did hear the noise though. we then brought it into the shop, and put it on the lift. we found the r/f tire to be badly cupped, and that the idler arm, pitman arm, and all 4 ball joints need replacing. we also corrected all the tire pressures, and rotated the tires. i haven't had a chance to get it up to highway speed yet, to see if it made any difference. tomorrow, i will try and see if it does it in 4wd. btw, we work in a car dealership, i work in parts, and the other guy is an ASE certified tech. Glenn Peters 12-04-2003, 01:07 PM I'm an ase certified tech.Just haven't had enough time,wheel bearings do go bad it's common on blazers from what I hear. Wasn't my problem, I'll keep you posted!!!! frankjc 12-04-2003, 02:40 PM i had the opposite side replaced a while back, when the car was under warranty, it was making a different noise though. it's 2000 miles out of warranty now. thanks, and i'll let you know if we figure it out too. Glenn Peters 12-04-2003, 09:02 PM Have sone one check out acctuator on the front axle, thats where I'm gonna start! Once I get a chance!!!!!!!!!! frankjc 12-04-2003, 09:17 PM think maybe they stick? or get partially engaged? frankjc 12-04-2003, 09:19 PM think maybe they stick? or get partially engaged? i can hear it when i switch into 4wd.... i talked to a chevy dealer today, and they couldn't think of any common problem that would cause this. Glenn Peters 12-06-2003, 11:39 AM Read my latest post under humming noise r/f !!!! Glenn Peters 12-12-2003, 08:53 PM Dude absolutely no luck yet,how about you???? Automotive Network, Inc., Copyright ©2012
