Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 12-03-2003, 12:12 PM   #1
edub70
edub70 Normal reputation
'87 Chevy K5 Blazer - No Spark - Help!
I could really use some help about now. Not getting a Spark from my '87 K-5 Blazer. Has a 350 in it. The whole problem started when I would start the vehicle cold. If I gave it a little gas, it would stall instantly. If I started it and did NOT touch the accelerator, it would idle for 5 to 10 seconds and then stall. Now the engine will not start at all and it is not getting a spark. I already changed the distributer cap, rotor, coil and control module. No luck there. Checked the wire from the Distributer into the fuse box and looks good. All the fuses in the main fuse box are A-OK. What next? I'm going crazy here! Thanks for your input!!!
edub70 is offline   Reply With Quote
Old 12-07-2003, 09:50 PM   #2
97blazerct
97blazerct's Avatar
97blazerct Normal reputation
Send a message via AIM to 97blazerct
i didnt read ur whole post but id say
re-align the gap in ur sparkplugs and or change the plugs and plug wires..
97blazerct is offline   Reply With Quote
Old 12-17-2003, 04:36 AM   #3
CaptainZoom
CaptainZoom Normal reputation
Re: '87 Chevy K5 Blazer - No Spark - Help!
What happens when U turn ign. key?
Does engine revolve, or is it dead? If revolving, here`s
a few suggestions..
First, check the colour of sparkplugs, if black and wet, U could have the same problem as i had. Gasoline had once filled the cylinder, went trough and mixed with the engine oil. Making the oil too thin. So when revolving the engine it brought up the mixed goo into the cylinders, shortcircuting the sparkplugs.
So start by checking oil level, if too high, drain and replace oil and filter.
If not...
Try putting a sparkplug directly in the wire,coming from the coil. Do U get a spark?
Now U know if there´s electricity in the system.
If not, the problem lies in, or before the coil.
New condensor? If not, replace with new.
Good Luck!
CaptainZoom is offline   Reply With Quote
Old 01-23-2004, 07:20 PM   #4
cjs_12345678
cjs_12345678 Normal reputation
Send a message via Yahoo to cjs_12345678
spark
wel i dont have an 87 but i did have the same problaem with my 90 it could be your distribitor or just could have been knocked so far out of time its not giving out any juice but my best bet that its your distriburtor
cjs_12345678 is offline   Reply With Quote
Old 01-23-2004, 07:34 PM   #5
brooster
brooster Normal reputation
You've already replaced the components responsible for creating the spark. Now, let's do some basics. With the key on, check the large wire (battery wire) which plugs into the coil at the cap. Does it have 12 volts (bright light)? If not, check for a burned fusible link at the starter or on the firewall under the hood. If you have 12 volts, make sure the wire is plugged in/onto the coil lug tightly.
Crank the engine with the distributor cap removed so that you can observe the rotor. Does it rotate? If not, you've probably blown a timing chain.
If you have rotation of the rotor and you have 12 volts to the coil, you're probably looking at a pickup coil problem. You'll have to unplug it from the module and test it with a ohm meter. I believe the spec is 500-750 ohms, but I'm not sure.
Note: Make sure the ground strap is in the cap for the coil.
brooster is offline   Reply With Quote
Bookmarks
Google
Web AF
