Does any of you (p11) have problems with rear calipers?
jprimera
12-15-2001, 11:15 AM
The calipers chake.
I have eard that the p11 have this problem (at list in my country) ,any ideas how to resolve it?
Thanks
Willy Estrada
12-23-2001, 06:02 PM
My calipers on my 99 primera made a whole lot of noise, i sent it to the dealer and they new not how to fix it, so i sent it somewhee else and they added silicone to shut them up. I guss you and i have the same problem.
Las calles enb nuestros paises son una mierda por ende tenemos problemas de aflojamiento de nuestros carros.
Where you the one who was going to buy a Blubird SR20DET? and swap it with your P11 engine? if so how did it go?
Luck on the calipers
jprimera
12-23-2001, 07:11 PM
Hi
Th e problem with ours car is from factory ,they put the calipers in the worn side ,is not becouse of the streets ,any ways the street helps:rolleyes:
My proyect hope will be next year or 2003 Y wont to make a n/a monster first ,by the way if you dont know ours car cut (rpm ) at 7350rpm
v_knot
01-03-2002, 03:31 PM
I have had similar problem with my former maui blue G20. I took it in the dealer and he took the caliper out and greased it and added some washers and it was okay until I rolled it. With the existing G20, on a very rough and bumpy road, I could hear the noise on the rear right caliper. The tools in the spare tire also added to the noise...
But lately it is fine......
pche059
01-04-2002, 01:49 AM
Hey can you guys briefly discribe what the noise sounds like?
and when does it happen?
coz i dunno what it is but there is some really strange and annoying noise coming out from my right front wheel arc....
could well be the caliper too....
v_knot
01-04-2002, 10:38 AM
I never had any problem with the front wheels yet.
The noise you get from the rear, possibly the calipers, is a tin tingling sound. The kind of sound is like if you take your cooking pan and hit it with a wooden bachelor. :) The sound is produce when the car is driven over a crack or bumpy road.
pche059
01-04-2002, 02:23 PM
hey man that's what my sounds like too...
it sounds like that there is something stuck between the brake pad and the brake disc....it happens whenever i am braking or doing the left turn (more like when the right front suspension is in compression)
that noise sometime happens with my front left wheel arc...
jprimera
01-04-2002, 09:12 PM
Or may be you have some problems with the suport of the suspention ,I do not know the name in english ,I will tel you later .My friend 1fast primera have some problems with this I will ask him
pche059
01-05-2002, 02:28 PM
yea that would be good man if you can do that :D
man i am worried...that noise sounds rather bad..
hm wonder if a worn brake pad or disc...or worn shocks with create noises like this...
