gains w/camprelude9384 12-02-2003, 08:52 PM What kind of hp gains should I expect with a aftermarket cam? Ace$nyper 12-02-2003, 11:21 PM sooo vauge. what cam what else done what motor what ECU. OMG give info needed to answer if you want help. I like helping but need teh info. Sweet lord i'm losing it! pbizzlegsr 12-02-2003, 11:53 PM sorry for taking your tread but..99 gsr..i/h/e..plan on installing ctr cams..with aem cam gears..how much gains? prelude9384 12-03-2003, 10:41 AM f22 sohc.......aem cai, 5zigen fireball catback exhaust, jet performance module and I have a aem adjustable cam gear to install.......w/headers and p/pulleys in the future Ace$nyper 12-03-2003, 12:51 PM ok cool what kinda cams you planning on? cause were still looking at a broad range for extra power like 5-30 hp. depending on what you get. SiGNAL748 12-03-2003, 08:35 PM cam :wink: prelude9384 12-03-2003, 09:00 PM Can't find hardly any cams for the f22......there's a topline cam here's the stat for it->2156cc 85mm, then there's gude.com, but their site is screwed up. PunkAlex 12-03-2003, 10:22 PM What you should look at moreso than the hp gains is where the cam makes its gains on the powerband-hell some cams just move power from the lower rpms to the higher-no gains at all. The general rule is the higher the duration, the more low rpm gains, the higher the lift, the more high rpm gains. Find a cam for your use. You can have high both if you plan on keeping it natural. Forced engines like high lift, short duration-they tend to knock w/ high durations. And like it was said, the cams are more effective when used with an aftermarket ecu. steffear 12-07-2003, 06:08 PM sooo vauge. what cam what else done what motor what ECU. OMG give info needed to answer if you want help. I like helping but need teh info. Sweet lord i'm losing it! I been looking around and I think comp cams are the best for my car b18c, I want to keep stock gsr manifold but possibly extrude hone that and the head. Dont want to raise red line either so something that will give me increased hp all over rpm range. what do you think of comp cams? There is a local seller here selling stage 2 skunk2 cams with aem cam gears for $700 what do you think of those, and the price? thanks!! Ace$nyper 12-07-2003, 09:44 PM Skunk2 stage 2 cams seems to be the #1 cam from everyone I know using them sounds like a good deal. Comp cams makes good stuff too. Skunk2 stage 1 is also very nice very smooth just a bit of step up on whole power band. Hope this helps. bbyzfr6 12-22-2003, 10:29 AM If you write in saying I am going to put a cam in my car with out any specs on the cam you must be clueless. FYI you already have a cam in your car. Hints the first reply to your post. Second more, duration doesn't mean more low end power. Higher lift increases power all over the rpm not just top end. The problem is to get higher lift duration must increase. Too much duration = no low end because you bleed off cylinder pressure. More duration equals bad idle and drivability in the low end. Why do you think they have vtec. For bigger cam lobes to kick a$$ on the top end, but have driveablity at the low end. For god sakes this lets get technical is a joke. How about you read your magazines a little more or maybe go to howstuffworks.com You could probably double your knowledge on valve trains in 5 min. prelude9384 12-22-2003, 06:59 PM wow.....an uber technician jcrx 12-23-2003, 08:09 AM ......there's a topline cam here's the stat for it->2156cc 85mm, That's not a cam spec. This is a cam spec... Int-240 dur. / 11.5mm lift Exh-235 dur. / 10.5mm lift prelude9384 12-23-2003, 06:13 PM thanx Automotive Network, Inc., Copyright ©2012
