oil pressure sending unitsarge1966 12-02-2003, 07:07 PM where is the oil pressure sending unit located on a 2001 chrysler intrepid? sarge1966 12-02-2003, 07:09 PM where is the oil pressure sending unit located on a 2001 chrysler intrepid? longhorn11 03-03-2004, 01:16 PM the oil sending unit on the 2.7 is beside the oil pan on the right hand side facing the front. it screws into the engine. quick fix 5spd 05-02-2004, 02:14 PM The oil pressure sender is located on the engine block (midways up), on the right side (left side if you are facing the engine). It has a one wire connector (I think the connector is green). xs29l 05-11-2004, 11:25 PM Your sensor is probably fine, but they are bad about leaking and the oil blocks the signal. I took mine off, cleaned it, and put some Blue Goo on it and it's just fine. No more oil light Automotive Network, Inc., Copyright ©2012
