b18c civic 98 swap?RoBoDEATH 12-02-2003, 04:15 PM i'm on the verge of buying a b18c is the b18c swap from a 98 civic ex hard? whats involved? I'm getting Motor - Hydrolic Tranny - ECU - Alternator - Starter - Clutch - Flywheel - Intake Manifold - Exhaust Manifold - Fuel Rail - Injectors - Distributor - Engine Harness - Comes With All Sensors Needed - Axles & shift linkage civic15.8 12-02-2003, 05:38 PM well what obd is the motor (or do yo not know)? if it is a obd1 motor then you will have to change some wiring to fit your harness. if it obd2a like your car then all you will have to do is add a few wires. the motor will bolt in with b series motor mounts. and you will have to get a throttle cable from a integra gsr also the exhaust might need to be welded together to fit but im not quite sure i believe that is it salbaje 12-03-2003, 02:53 AM you will need mounts, ecu Automotive Network, Inc., Copyright ©2012
