weird blinker problemjazer80 12-01-2003, 02:07 PM okay i put new bulbs in cuz i still had 55 watt bulbs in my projectors (though they still suck even w/ 100 watt bulbs) , and messed something up, cause now my blinkers don't work. in the process of putting in the bulbs i blew a fuse, and there was already a blown fuse for my hazards. i replaced both fuses, checked all visible wiring, and now all my lights work, but my turn signals won't work, even though my hazards will still flash, so i don't think it's the piece that makes the flashing. has anyonhe had this happen? jazer80 12-02-2003, 04:40 PM oh its a 95 accord ex if that matters, prolly doesn't. please help i keep getting pulled over IntegraBoy2003 12-03-2003, 12:56 AM hmmm that is odd chixSI 12-03-2003, 05:24 PM you need to check your combo switch! the combo switch is the unit that has the windshield wiper and headlight control. it is behind your steering wheel so you will have to remove the steering wheel and air bag to get to it! pain in the butt...if you don't want to do this, take it to your dealer! jazer80 12-03-2003, 10:50 PM is this something i will be able to figure out? do i just remove the airbag fuse (is there only 1?) and go to work on it? oh my srs light is already lit up so i don't think it matters if i mess around w/ it chixSI 12-04-2003, 12:09 PM yeah you can figure this out i have faith in you, basically what you have to do is disconnect the battery (no need to remove the fuse when there wont be any power if you disconnect the battery.) then remove the steering wheel and air bag to get to the combo switch. you will have to remove the plastic cover, pretty easy only about 2 screws! then yeah you work on it from there! thats pretty much it...if this doesn't help you out then i dont know what will!!!! Good Lucky man!!! chixSI 12-09-2003, 10:19 AM hey just checking up on yeah! i haven't heard back from ya so i take it you fixed it or trying to fix it! i hope it worked! let me know Automotive Network, Inc., Copyright ©2012
