Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 11-30-2003, 08:52 PM   #1
blueturtle00
blueturtle00 Normal reputation
Camber, Caster Alignment?
Does anyone know if there is a Caster or Camber alignment on a 98 windstar? If so how can i adjust it.
thanks
blueturtle00 is offline   Reply With Quote
Old 03-29-2005, 10:22 AM   #2
jtman04401
jtman04401 Normal reputation
Re: Camber, Caster Alignment?
Yes there is.. but from what I understand it is a hell of a job to adjust it. You must remove the whiper shroud, whiper and whiper motor, drill out the rivits that are holding the strut from adjusting then losen the 3 strut mout nuts and adjust it. If you are going to try this yourself you will never get the right camber/caster. If you take it to a front end shop they can do it but it will take them about 3 hours worth of work just to get to the adjustments. So best bet is to do all the removing of the whiper and such yourself then drive it to a front end shop and have them do the adjusting then you finnish the job by putting it back together yourself. It will save you about 6hours in labor if you get everything ready for them to set the camber n such.
jtman04401 is offline   Reply With Quote
Old 03-29-2005, 06:39 PM   #3
wiswind
wiswind Normal reputation
Perhaps.....have the shop check the camber/caster....to see if it is out......
wiswind is online now   Reply With Quote
Bookmarks
Google
Web AF
