reseting the ECU by hazard fuseRedRacerCivic 12-14-2001, 07:52 PM Is resetting the Ecu by pulling the hazard fuse for 10 seconds still clear the memory and truly reset the ECU? 82civicwagon 12-15-2001, 02:18 AM ive never heard of doing it that way, are you trying to get rid of a ckeck engine light? most vechicles if you disconnect the battery on both posts overnight it will reset , you need to let it sit a decent ammount of time if its a newer car due to the newer ecu's have capassitors in them that keep them awake for a peroid of time after disconnecting the battery.:D 91b16sedan 12-15-2001, 02:20 PM In the service manual it tells you to pull the hazard fuse to reset your ecu. I have reset my ecu like this every time i have had to do it, and it worked fine. :flash: Automotive Network, Inc., Copyright ©2012
