Right Rear Wheel WobbleCutlassGal 11-30-2003, 11:17 AM I have a 1995 Olds Cutlass Supreme and between 20-35 mph the who car seem to wobble. I have checked the tires and they are all good. Brakes are all new. What could be causing this? I need to get it figured out cause it seems like the whole wheel is going to come off. Any help would be appreciated. shekky 11-30-2003, 01:01 PM you may have loose lug nuts holding the tire on. or the tire needs to be balanced. Genopsyde 12-02-2003, 02:32 AM tie rod ends or ball joints The Burning Rom 12-02-2003, 10:51 AM tie rod ends or ball joints Rear wheel dude... :screwy: Check the lugnuts on that wheel. Make sure they're torqued down to specs (80-90lb-ft). Make sure there is no damage to the trailing arms or the lateral arms/mono-leaf spring. Inspect the strut-tower. I doubt that could have much to do with it, but just check it out. If none of those things turn up as problems, then I'd have the wheel re-blanced. That's about all I've got for right now..... :eek7: shekky 12-02-2003, 11:36 AM tierod ends.. it's a cutlass not a dodge stealth. the rear wheels dont turn. Genopsyde 12-11-2003, 03:28 AM i didn't see that part sorry mike&susan 12-16-2003, 12:08 PM I have the same thing only in the front left wheel. i was told it was the CV joints on mine. is that right just double checkin while the subjects up. shekky 12-16-2003, 12:53 PM could be a few things. the rear and front wheels are two different animals. The Burning Rom 12-16-2003, 02:23 PM could be a few things. the rear and front wheels are two different animals. I agree...there are a LOT more things that could cause problems in the front as apposed to the rear. Automotive Network, Inc., Copyright ©2012
