Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 11-30-2003, 10:03 AM   #1
oneGM
oneGM Normal reputation
Rushing water noise inside 1995 Blazer
I hear a rushing/ gurgling water noise when the vehicle makes sudden movements. Also the temp gauge fluctuates all the time when warmed up.(between 195 and 220) If there is air in the cooling system , what is the best way to get it out? I just bought this, it has 83K on it. Thanks!
Also should a 1995 be running orange coolant?
oneGM is offline   Reply With Quote
Old 11-30-2003, 10:49 PM   #2
oneGM
Unhappy
Someone must have had this happen. I am mainly worried about the fluctuation of the temp guage. There seems to be no ryme or reason for when it happens, Sometimes it drops down to 195 while sitting at idle and sometimes it drops down when you race the engine. sometimes it goes to 220 at idle and when you race the engine? HELP!
Old 12-02-2003, 03:10 PM   #3
jmdennisyourface
jmdennisyourface's Avatar
jmdennisyourface Normal reputation
Send a message via AIM to jmdennisyourface
Re: Rushing water noise inside 1995 Blazer
Sorry, I can't help you with the temp gauge, but I also had the water rushing noise in my 95 Blazer. It was caused by a tiny hole in a gasket near the water pump. I had two mechanics look for the source before one found it. This was a couple months after he had replaced the water pump and not noticed it. Good Luck
jmdennisyourface is offline   Reply With Quote
Old 12-02-2003, 08:40 PM   #4
JOE CLARK
JOE CLARK Normal reputation
I have 97 blazer with same rushing sound. I just had the intake manifold gasket replaced. Could there be a connection? Have you solved the rushing noise?
JOE CLARK is offline   Reply With Quote
Old 12-04-2003, 09:34 PM   #5
Harmon
Harmon Normal reputation
one GM
My dad and I own a garage and the blazer is notorious for temp gauge problems.
Have u checked your cooling fan clutch to make sure it is good?
Alos those gauges sometimes just wear out.
Hope this helps.
Harmon is offline   Reply With Quote
Bookmarks
Google
Web AF
