Beep! Beep! Horn help!
95supreme
11-30-2003, 02:13 AM
My horn works on and off on my 95 cutlass supreme. Is there any danger to taking off the steering wheel cover to check the switches?
Will my air bag deploy?
Thanks!
shekky
11-30-2003, 01:05 PM
remove the airbag fuse to be safe, but i have removed many wheels, never having the airbag deploy.
95supreme
11-30-2003, 11:41 PM
Thanks Shekky.
I knew that I had to take out the fuse, but I wasn't sure if there was another backup fuse, or relay I had to disable too.
89calais
12-06-2003, 08:44 AM
Sometimes the fuses being removed isn't enough , sometimes theres an electrical relay running to the steering wheel. Simple - Remove positive cable connection from the battery terminal =D
shekky
12-07-2003, 10:40 AM
there is a back-up power supply for the airbags.
disconnecting the battery wont affect it.
you shouldnt have a problem anyways.
95supreme
12-07-2003, 07:36 PM
The horn was fixed!
It ended up being a few blown power relays that were causing all my electrical problems!
