Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-30-2003, 12:51 AM   #1
95supreme
95supreme's Avatar
95supreme Normal reputation
Please Help! Overheating!
I recently bought a 95 cutlass supreme. 3.1 V6.
The engine is running hot, and it seems that the fans aren't always working.
There's enough coolant, and the radiator is new.
If the car is being used for only a few hours, it's not noticable. However, after using the car for about 8 hours, I started to smell the heat coming off the engine.
Also, the engine loses its power and seems that it has no excelleration when the motor's too hot. The temp guage reads a little high, but out of the danger zone.
So, is it my thermostat, my radiator fan, both, or something else totally different?
I'm also wondering if it's an electrical problem too. After the car's been running for about an hour, the ABS light comes on.
Also, the fog light switch indicator is on, but the lights themselves don't turn on.
I've only had the car a few days, and haven't had the chance to check the fuses or relays under the hood yet. I hope it's something that simple!
Needless to say, I would probably have more problems if it was summer, instead of -5c in winter!
Any insight would be greatly appreciated!
95supreme is offline   Reply With Quote
Old 12-06-2003, 04:22 AM   #2
89calais
89calais's Avatar
89calais Normal reputation
Re: Please Help! Overheating!
Well , IF just may be that the thermostat is bad. You could have a grinding water pump or the heater core unit may be frozen. DO you get heat ? Do you hear any squealing sounds from under the hood or grinding noises of metal ? Thermostats are cheap and the gasket for the thermostat housing is even cheaper , go with that first. Oh , Check your dipstick as well , see if you have any white mucus on the oil level indicator or any part , You may have bad head gaskets and the over heating would result from the high friction and lack of proper lubrication..happened in a subaru XT6 I owned one time. Hope that helps some.
89calais is offline   Reply With Quote
Old 12-06-2003, 07:22 PM   #3
madman_9
madman_9 Normal reputation
Look
And if you turn your a/c on if the fans come on they work. The fans in my car (94 3100 cutlass) about 225 or so.
Madman
madman_9 is offline   Reply With Quote
Old 12-07-2003, 07:38 PM   #4
95supreme
95supreme's Avatar
Well, unfortunately my a/c doesn't work. But, I think my problem is the thermostat. I'll replace it soon, and post the results here. Thanks for your advice.
Old 12-08-2003, 03:42 AM   #5
89calais
89calais's Avatar
If you live in a warm climate area , I recommend just taking it out and never putting one back in. Prolongs engine life , allows it to run about 30% cooler ( less engine wear and gas consumption. ) Smoother over all =)
Bookmarks
Google
Web AF
