2002 expedition keypad help!!!!
heatseeker1
11-29-2003, 11:34 AM
can anynone please help me locate codes cant seem 2 find them anywhere
ljrnld
01-27-2004, 12:25 PM
i have an explorer the code is on a silver box in the cargo area over the tire hump on the drivers side
RJExp
02-10-2004, 11:17 AM
If you have the packet with the owners manual, it should be on a card in that packet. If not then look under the drivers side dash up on the firewall there should be a black box with a white sticker on it with 5 large numbers on it. The first four are the access code. Pressing 5 at the end will unlock the driver's door.Then pressing 3 will unlock the other doos or pressing 5 again will unlock the rear door. Pressing the last two buttons simultaneously will lock all the doors.
95gt4me
03-08-2005, 04:33 PM
If you have the packet with the owners manual, it should be on a card in that packet. If not then look under the drivers side dash up on the firewall there should be a black box with a white sticker on it with 5 large numbers on it. The first four are the access code. Pressing 5 at the end will unlock the driver's door.Then pressing 3 will unlock the other doos or pressing 5 again will unlock the rear door. Pressing the last two buttons simultaneously will lock all the doors. hi i also have 02 expedition (eddie bauer) my code was located in the rear behind the panel on the drivers side that covers the the rear ac unit it was tucked way in on an orange sticker hope this helps.
