car sputter and stutters, sometimes won't accelerate, and dies!
BOTLFED98
11-25-2003, 09:08 AM
....here's my problem right now i just got the car and it ran really good for 1 day! now the thing is all messed up, it is a '96 EX 2dr automatic and when i accelerate sometimes the RPM's will jump up then straight down to zero....sometimes if i keep giving it gas it will want to accelerate and othertimes it will just be dead and i have to put it in neutral and restart it! even when i rev it in "park" it will stutter and act like it won't get past a certain rpm...what the heck could my problem be? keep in mind it doesn't do it all the time....i need to get this thing fixed asap cause i'm supposed to drive it down to FL in 2wks!
BOTLFED98
11-25-2003, 09:10 AM
keep in mind there r no cel or anything like that....
Ricochet
11-25-2003, 01:57 PM
Tech help aside, you need to take that bitch back to wherever/whoever you bought it from and get it fixed for free, or get your money back. There are lemon laws and having a car screw up after one friggin day just isn't right.
BOTLFED98
11-25-2003, 03:07 PM
ya, well i bought it used from a private owner as is....it ran fine, well for a day! anyone have a clue??
Ricochet
11-25-2003, 03:37 PM
uh yeah take it back to him/her and ask for your money back.
A stuttering engine could mean a dozen things from you're out of gas, a clogged fuel filter, to fried piston rings or a blown head gasket... Did you drive hard or do something to make it fuck up?
BOTLFED98
11-25-2003, 05:54 PM
it was fine the first 2 days i got it, and yes i drove it hard....but not to f something up majorly i wouldn't think! i'm def not out of gas, and i even ran the 87 out and put 89 in it....fuel filter def could be clogged tho!
Ricochet
11-26-2003, 09:00 AM
only advice is try changing your spark plugs again, maybe you bought the incorrect ones. Also check your distributor by taking off those 4 screws, and look at the little rotor thing in there to see if it's maybe rusted or something. These parts are cheap relative to taking it to a dealer.
BOTLFED98
11-26-2003, 10:39 AM
ya, i never changed the plugs...i didn't change anything i just got the car and it started acting up! i will start changing stuff i guess cause i hate to take it into the dealer and get bent over! the distributor only has 3 screws and not 4 correct?
oh, BTW NOW IT IS IN MY GARAGE AND WON'T EVEN START!!
Ricochet
11-26-2003, 10:42 AM
3 or 4 philips screws... don't remember, but you get the point. And yes, dealers do rape you.
Esox814
11-26-2003, 11:34 PM
It's more than likely an electrical problem. Mechanical problems aren't intermittent, most of the time. Check your grounding wires, I would change spark plug wires and the rotor cap. You might consider investing in a service manual if you like to do it yourself. They usually have troubleshooting trees that help diagnose problems like you have.
