5 speed manual fluid type
sturgis
11-22-2003, 10:39 AM
This has probably been asked but "Search" won't seem to work for me.
5 speed noisy in my 93 delSol. Don't know if ever serviced. Wish to drain and re-fill.
Could someone please provide fluid type and capacity?
Thank you in advance, Sturgis
mtdxx
11-22-2003, 12:49 PM
I changed the fluid in my 94 DX. It took 10W30 motor oil. I think alot of hondas use that in the manual trans. But best to look it up to be sure.
Dumped91Hatch
11-22-2003, 02:45 PM
There is Honda MTF and you can use 10w30 oil. I think the capacity is like 2.5qts or somewhere around there.
BullShifter
11-22-2003, 11:58 PM
Unless the fluid is VERY low, changing it will not fix a noise, the damage has already been done. A lot of people seem to think gear lube(75w-90) helps, all it does is cover the nosie & make things worse over time.
Manual is about 2 qts
Honda MTF is recommended but, like posted above you can use 10w-30 engine oil, I'd go with 10w-40(max) in your case due to the noise.
i_a_n112784
11-23-2003, 03:44 PM
On honda manual ones, just fill it until it can't hold anymore. On automatics you need to measure.
mtdxx
11-23-2003, 09:56 PM
cool, anyone know where you can pick up the body clips that hold the doors on? Can I just go down to auto zone or pep boys. Those damn things always strip/break or get lost.
